LabWindows/CVI
ActiveX StatusBar
I'm looking for an example or description how to use
the ActiveX StatusBar.
I use Labwindows/CVI 6.0.
(3,234 Views)
For most purposes that a Status ( I am assuming Progress Bar here ) you can use a horizontal slide bar found under the heading of ring on the pop-up menu for the controls. However, if you need some active-x control example, the best to go is to the website of the company that produced that active-x control. I am thinking that you are trying to use a Microsoft Statusbar control. I am sure that someone out there has an example using that control in a C-based compiler.
Good Luck!
Joji
(3,234 Views)
