LabWindows/CVI
Active X & Netmeting.
I have used the CVI tool "Create Active X Automation Controller" to produce
a Netmeeting 1.1 Type libary.
It was then very easy to write some CVI code to communicate with it using
audio only. Does anyone know what is needed to get video?
John Cameron.
(3,233 Views)
The documentation for using the NetMeeting COM API can be found at the Microsoft Developer Network at http://msdn.microsoft.com/library/default.asp?url=/library/en-us/netmeet/nm3com1_8m09.asp
A listing of all of the interfaces and objects that the API exposes can be found at http://msdn.microsoft.com/library/default.asp?url=/library/en-us/netmeet/nm3com1_84c3.asp
Lastly, specific information regarding the video interface is listed at http://msdn.microsoft.com/library/default.asp?url=/library/en-us/netmeet/nm3com1_23as.asp
Just read through this documentation and I'm sure you will be able to find the corresponding function calls that you need within your ActiveX Automation controller library to add this functionality to your CVI application.
Jason F.
www.ni.com/ask
(3,233 Views)
