LabWindows/CVI
Active-X Error after implementing security settings
I am a developer on a radar test equipment project using LabWindows 2013 SP2 on Windows 7 Ultimate edition.
Our project uses an Active-X control from Foresight Imaging to display radar video using a frame grabber card.  The Active-X component file is loaded into the Windows registry using the "regsvr32" command.  The program runs on a PC in a closed lab.
Recently our Security official had to implement a bunch of new settings and protocols on the PC at the direction of the Defense Security Service (see the attached document).  Now when I try to run the program, I'm getting a popup message that says "Error code -143: ActiveX control error".  The program will only run if I right-click on its icon and select "Run As Administrator".
We are both combing through the document trying to find which setting is responsible for screwing up the program, but we haven't figured it out.  Any ideas?
(5,167 Views)
You may want to give this knowledgebase a look over:
http://digital.ni.com/public.nsf/allkb/ECFFD8EC36AE92B9862575C20061B2D1
Please let me know if this doesn't help.
Jonathan R.
(5,137 Views)
It didn't work, I'm still getting the same error.
(5,133 Views)
The situation in the knowledge base article involved someone trying to run a previously built executable on a different PC.  I'm running on the same PC as before, just with different security settings.
(5,130 Views)
Hi richferrara,
Is the ActiveX control in a location on your computer which now requires different user permissions to access than before?
Does this behavior happen when you use this ActiveX control in a different environment (Visual Studio, LabVIEW, etc)?
Does the vendor of the ActiveX control impose requirements on user privileges?
Daniel Dorroh
(5,058 Views)
The controls are in the following locations on the PC's hard drive:
c:\Program Files\Foresight\Idea\System\IdeaCtls064.ocx
c:\Program Files (x86)\Foresight\Idea\System\IdeaCtls.ocx
I am an Administrator on this PC so I am able to get to these folders/files and set their security settings to give all Users full control, but the only change in the results is that the error changes from -143 to -145.  I don't know of any restrictions imposed by the vendor.
We are not using any development environments on this PC other than LabWindows.
If we can't find a way to fix the security settings, is it possible to somehow use LaunchExecutable or some batch-file function from within a LabWindows program to automatically launch another executable with administrator privileges?  I'd be looking for some function call that does the same thing as right-clicking on an icon and Windows and selecting "Run As Administrator", but from C code.
(5,052 Views)
Our security person found the problem.  It was this setting:
User Account Control: Run all administrators in Admin Approval Mode
https://technet.microsoft.com/en-us/library/jj852217.aspx
(5,034 Views)
