LabWindows/CVI
Acquisition Thread Delayed by main thread ?
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 10"><meta name="Originator" content="Microsoft Word 10">
Hi I have the following setup. I have created a new thread from the default thread pool to do my acquisition. I basically move a stage and take a camera image to build up a large image of a region.
Each time I move the stage and get a camera image. I then add this image to a thread safe queue.
I have also setup a callback to be called when data is written to the queue. This callback should get called in the main ui thread I believe, so it is where I display the images.
My problem is that the callback seems to interrupt the acquisition thread. I.e. if I get the callback to be called when 5 items are added to the queue the stage moves 5 times with now delay, but on the fifth there is a delay when I remove the items from the queue and display them.
Should the acquisition thread be able to continue with any delay?
PS this is a multi processor machine.
If I put a Delay(2.0) call in the callback function it also clearly delays the acquisition thread.
Does anyone have any ideas?
Message 1 of 8
(4,633 Views)
Hi Glenn.
It seems to me that you have set the threshold values for both the acquisition and main thread callbacks to be equal to the maximum TSQ length (which is apparently 5), so that:
  • the callback for EVENT_TSQ_ITEMS_IN_QUEUE will not fire (in the main thread) until the queue length reaches 5
  • the callback for EVENT_TSQ_QUEUE_SPACE_FREE will not fire (in the acquisition thread) until the queue is empty
This would explain the delays you have observed, and may also cause problems with handling the last few images.
I suggest you try something like this:
// In your acquisition thread:
CmtInstallTSQCallback (tsqHandle, EVENT_TSQ_QUEUE_SPACE_FREE, 1,
        AcquireNextImageCallback, NULL,
        CmtGetCurrentThreadID(), NULL);
// In your main thread:
CmtInstallTSQCallback (tsqHandle, EVENT_TSQ_ITEMS_IN_QUEUE, 1,
        ProcessNextImageCallback, NULL,
Keep the maximum queue length as is, so that user interface activity has minimal impact on the acquisition.
Hope this helps.
Colin.
Message 2 of 8
(4,595 Views)
Well this is what I have
static int CVICALLBACK AcquisitionThread(void *data)
    // Thread controlling the xy stage.
    // Does a stage move as soon as the previous acquisition is complete.
   // Get image create tile etc
   tile = ....
   CmtWriteTSQData(rs->queue, &tile, 1, TSQ_INFINITE_TIMEOUT, &number_flushed);
static void CVICALLBACK QueueReadCallback (int queueHandle, unsigned int event, int value, void *callbackData)
    if(event != EVENT_TSQ_ITEMS_IN_QUEUE)
        return;
    // Removes the tiles from the queue
    if((items_in_queue = CmtReadTSQData (rs->queue, tiles, items_in_queue, 20, 0)) < 0)
        return;
   Delay(2.0);
    for(i=0; i < items_in_queue; i++) {
        tile = &(tiles[i]);
        // Process tile in main thread
void Run()
      CmtInstallTSQCallback (rs->queue, EVENT_TSQ_ITEMS_IN_QUEUE, 1, QueueReadCallback, rs, CmtGetCurrentThreadID(), &id);
      CmtScheduleThreadPoolFunction(DEFAULT_THREAD_POOL_HANDLE, AcquisitionThread, rs, &acquisition_thread_id);
      CmtWaitForThreadPoolFunctionCompletion (DEFAULT_THREAD_POOL_HANDLE, acquisition_thread_id,
                OPT_TP_PROCESS_EVENTS_WHILE_WAITING);
I still get the delay though with one item added at a time ?
Maybe I misunderstood your answer though.
Thanks for the help.
Glenn
Message 3 of 8
(4,580 Views)
Hi Glenn.
It looks like AcquisitionThread() is called repeatedly to acquire the entire image. Is this correct?
If so, the delays you see are probably due to the overhead of continually scheduling this function. Try placing the repeated steps inside a loop:
  // Initialise
  while (acquiringImage)
    tile = ....
    CmtWriteTSQData(rs->queue, &tile, 1, TSQ_INFINITE_TIMEOUT, NULL);  // I assume you are not using auto flush
  // Complete image processed, so clean up and return
With this logic, you won't need the
EVENT_TSQ_QUEUE_SPACE_FREE callback.
Have a look at the BuffNoDataLoss sample project in the Samples\Utility\Threading\ThreadSafeQueue folder. You don't need all of its bells and whistles, but the basic structure appears suitable for your application.
Good luck.
Colin.
Message 4 of 8
(4,566 Views)
No it only schedules the acquisition thread once.
The acquisition thread sits in a while loop until the stage has moved over a large region.
So it continues to add images to the queue for each image that makes up one large region.
  // Initialise
  while (x, y in rows * cols)
    Move to x y
    tile = ....
Putting the Delay in the read callback definitely stops the stage from moving for the length of time specified in Delay function even though it is a different thread ?
Message 5 of 8
(4,558 Views)
Ah hangon. Writing that previous reply has helped me wake up.
I communicate with the stage through a com port I have locks protecting that ComWrt so I can communicate with it through different threads.
Maybe keeping the main thread occupied is preventing the processing of the comport data ?
Message 6 of 8
(4,557 Views)
No the comport is interrupt driven so it should be ok.
Message 7 of 8
(4,556 Views)
I'm not using auto flush by the way.
Message 8 of 8
(4,554 Views)
