LabWindows/CVI
Acquire and Generate Analog data
Hi All,
I am trying to acquire and generate data at the same time (AI from Chan1&2, AO from ao0).  I am using the AO channel as the Differential Ground for Chan2 (just a DC voltage).  I was wondering if anyone could tell me how to acquire and generate together?  Example code would be nice.  Thanks.
Cheers,
Tdk
(2,911 Views)
The Developer Library on this site if a valuable source of examples and reference code that anyone can staudy and reuse/modify. I suggest you to perform a search for "simultaneous AI and AO": amont other examles, you will find this one [broken link removed; example no longer available online] that looks as very basical so to introduce you in this matter. Other examples are present that are more specific to some particular aspect of this environment.
Hope this helps you in your job
(2,905 Views)
