LabWindows/CVI
Access Excel Cell by Name
Has anybody accessed Excel cells by name rather than cell numbers? Similar to bookmarks in word.
I ahave created a data sheet template in excel. I fill in this template from xml data generated during a test run. I would like to use names as it can be more descriptive than cell numbers.
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
(3,085 Views)
I think you may be looking for Range("C2")
As to formatting information, this is available through various properties of the Excel object model.
See http://msdn.microsoft.com/en-us/library/ff197454.aspx for more information.
The Range type (as opposed to the Range indexed property referenced above) also exposes a Name property, which you can set in code:
worksheet.get_Range("C2").Name = "fdafdfs"
worksheet.get_Range("fdafdfs").Select();
Kudos are welcome 😉 marked solutions are awesome!
(3,046 Views)
Thank you Hector!
John O'C
Woodward, Inc.
Wow...What a Ride!"
(3,028 Views)
