LabWindows/CVI
About niSwitch
hi,
currently i am working with NI 2530 mux  with NITB 2631 Matrix block(4x32). I am using this to get CAN signal & pass it through the Scope.
i want to access the Switch from CANoe, so now i am writing some driver for this Switch in CVI & then i will call this to CANoe.
i want know if i give 2 signals to same row whether it can detect error by it self ? if so then what function should i use.
please give me some suggestion..
(3,685 Views)
Hi praky,
I'm not sure I understand correctly what you are trying to do. Are you trying to make a differential measurement with your scope to extract the error?
How to do this you can read here: http://zone.ni.com/devzone/cda/tut/p/id/3286
This link also includes an example for this.
Regards
DianaS
(3,662 Views)
i will explain it clearly..i have 10 CAN siganls. These signals are passed through a  test setup which has 4 ouput. In that Test Setup i have different Hardwares like NI's DMM, MUX , Matrix Terminal block and so on.. i want to analyse those siganls in Scope(Tektronix). for this purpose i was using   NI Switch Soft Front Panel 4x32 Matrix.
but now i want do the same thing without using the Front panel. so now  i am creating some drivers  using  Labwindows. In that i have few functions like
niSwitch_init, niSwitch_Connect..
so i have 4 rows to connect to scope & 32 columns to get CAN signal. for example i can connect  r1-c1 , r2-c2, or r3-c10 & so on..
my Question is what will happen if i connect one row to two columns(r1-c1&c2).
Does it detect error automatically or should i avoid it in my labwindows program.
i hope now u can understand my Qn.
Praky..
(3,642 Views)
Hi praky
its not automatically detected if you make a double or wrong connection. But with Switch Executive Software you can exclude connections:
http://www.ni.com/switchexecutive/d/
Regards
DianaS
(3,584 Views)
