LabWindows/CVI
ANOTHER CVI BUG !
In my last post I was talking about a strange behaviour, I've done some testing and here is the result, if you have many panel arranged in TAB format or menus and you are using a CWGraph, well don't popup nothing over the activeX control. In my case I used a popup menu over my CW graph giving the options to the user to set the Zoom cursor etc...and my tabs and everything out of my current panel was freezed. If I popup the same menu but not in the area of my ActiveX control, but still inthe same panel, everything works fine. So I'm asking you guys is this a bug, I had another one two days ago and National confirmed it, will you guys confirm this one to ?, I expected a better product bug free from National, I don't think we are paying 3500$ for a software o
nly to read buttons and light up LED's...
(2,990 Views)
Please try and be patient and we will look into this. The other issue you found was with a brand new feature, Annotations, and we are fixing it currently. This most likely is NOT a bug, but a windowing issue with you switching between three active windows. We can't solve these issues instantly though since we need to reproduce and diagnose the problem. If you want to speed up the process, then send a project that demonstrates the problem to our support engineers at http://www.ni.com/ask and it will save some time. I'm sorry you have run into difficulties and we will continue to help you as much as we can.
Best Regards,
Chris Matthews
Best Regards,
Chris Matthews
(2,990 Views)
