LabWindows/CVI
ADO without SQL Tollkit
Hello
i need the way for read and write a value into a Access database.
I have the activex ADO 2.8 but i didn't know the way from oben to close.
I created a new object with "New_Connection (NULL, 1, LOCALE_NEUTRAL, 0, &objHandle_SQL);".
Then i open this with "ConnectionOpen (objHandle_SQL, NULL, "DSN=TEST_CVI;", "", "", -1);".
Then i do "ConnectionExecute (objHandle_SQL, NULL,
"Select * from Test", &RESULT, -1, &objHandle_SQL_RECORDSET);"
If after the last Commando the data into the Recordset?
I have a error then i will read the numbers of line in the recordset with
"RecordsetGetRecordCount (objHandle_SQL_RECORDSET, NULL, &LONGPTR);"
But he give me a error after the last one.
I think i have a generally Problem with my way.
Thanks for your answer.
(3,454 Views)
Dear Wolf,
unfortunately we at NI don't have any experiences with this ActiveX interface you described. Maybe the documentation of the ActiveX interface can provide you the requested information.
Carsten Sprung
NI Germany
(3,412 Views)
