LabWindows/CVI
A ping function
Is there a library function to ping a device?
Message 1 of 9
(7,429 Views)
There is no ping function in CVI or the Windows SDK. Ping is a system-level command that is provided by the OS. The best way to do a ping in CVI, is to use LaunchExecutable to run ping and redirect the output of ping to a file. You can do this by building a batch file with something like:
ping.exe 172.16.19.60 > data.txt
Then call LaunchExecutable on the batch file. Then you can open the data.txt file to find the results of the ping.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
Message 2 of 9
(7,429 Views)
I can do this in dos, but when I try doing this command in cvi ping.exe 10.1.1.2 > data.txt,it doesnt work any ideas? I think it does not like the >
Message 3 of 9
(7,429 Views)
Try Status = LaunchExecutable (" ping.exe 10.1.1.2 > data.txt");
Luis Villa
"truc" wrote in message
news:506500000005000000CB1E0000-984882144000@quiq.com...
> does not like the >
Message 4 of 9
(7,429 Views)
File redirection is provided by the command interpreter so use the following:
Status = LaunchExecutable ("command /C ping.exe 10.1.1.2 > data.txt");
Michael Harrison
NI
Message 5 of 9
(7,429 Views)
Hi
Did you manage to get the ping function using cvi to work? Please mail me the solution if yo where successfll.
Thank You
Arik
arikl@gilat.com
Message 6 of 9
(7,428 Views)
I built my ping function adapting some sample code provided by Microsoft to use it in a CVI proejct. The code is in the source file attached: to use it you must also include in your project the library WS2_32.LIB (found in \sdk\lib directory).
I've used it in a CVI 5.5 project on a Windows98 machine and it worked well. I tried to transfer it to a Win95 machine, but had to download the winsock2 utility from Microsoft site: after that all worked well too.
To use it simply call the Ping (hostname) function: it returns 1 if the host was found, 0 if not.
Hope this helps.
Roberto
Message 7 of 9
(7,428 Views)
Let's try :
      int InetPing (const char *address, int *available, unsigned int timeout);
as suggested in CVI Help menu
Regards, David
Message 8 of 9
(4,583 Views)
You're right, a lot of things have changed in the 17 years passed from my last post in this discussion! Smiley Wink
Message 9 of 9
(4,578 Views)
