LabWindows/CVI
I cannot find a manual or driver for an old HP8157A attenuator.  I figured out that the command ATT XX.X sets the attenuation, but I need to also set the wavelength.  WAV XXXX seemed logical, but doesn't work.  Anybody have a manual or driver for CVI?
(3,664 Views)
Hi.
I found this with help from Google. I believe the 8156A and 8157A are similar devices, so hopefully the command syntax will be compatible.
Good luck.
(3,657 Views)
found it
The command set for 8157A is similar to 8158.
For example
query wavelength : wvl?
http://cp.literature.agilent.com/litweb/pdf/08158-90012.pdf
(3,437 Views)
