LabWindows/CVI
8145 LED Labwindows
I would like to control the USER2 and USER3 LEDs on the 8145RT from LabWindows.  I need to know what register to write to and the format of the register.
(3,934 Views)
Hi Tanner,
I have brought up the issue to National Instruments' R&D department.
I will post another reply as soon as I will have an update on this issue.
Sammy Z.
(3,907 Views)
Hi Tanner,
There is a way to do this is LabVIEW Real-Time, but there isn't a function in CVI to do this.
On the other hand, you can call the libraries that LabVIEW uses and use C functions to set the LED values. (This requires you to have LabVIEW.  Please let us know if you don't have LabVIEW)
The 2 libraries that the LabVIEW vi calls are:
  • Function Name: LedOutput
  • Function Prototype: int32_t LedOutput(int32_t led, int32_t value);
  • Location:  C:\Program Files\National Instruments\LabVIEW 8.6\Targets\NI\RT\vi.lib\ni_emb.dll
  • Function Name: LedInput
  • Function Prototype: int32_t LedInput(int32_t led);
Sammy Z.
(3,868 Views)
That'll work just fine.  Thanks for the quick answer.
(3,865 Views)
