LabWindows/CVI
64 bit CVI distribution kit installtion issue on windows 10 OS
I have been using Lab Windows/CVI 2015 for a while now and recently having issues with 64-bit version distribution files on Windows 10 OS. Not on all the computers we are seeing this issue but the number is growing from time to time. 32-bit version distribution files has no issue on the same computer though.
Did anyone experienced this behavior and if so have you found the root cause? Appreciate your help.
(2,319 Views)
You didn't post any details about the issue. Are you sure you didn't forget to attach a screenshot or something?
S. Eren BALCI
IMESTEK
(2,315 Views)
Sorry about that.
Unfortunately I don't have any picture or screenshot of the issue but the issue is that while installing the 64-bit version it will progress to 3/4% and then it just freezes there, every time same issue. But if you install the 32-bit version on the same computer no problem. Both 64-bit and 32-bit version files works fine on the other computer. Disabled any firewalls or anti-virus settings which are blocking the installation but still the same concern.
(2,309 Views)
There maybe a log file which gives details about installation process. An NI expert may answer this better.
S. Eren BALCI
IMESTEK
(2,301 Views)
