LabWindows/CVI
6 Problem Using data Socket in LabWindows
I wrote Simple Application to communicate with web application using
DataSocket, when Getting Response from the Web page first character is
dulicating 3 more times and overlapiing the rest of the String,
e.g.
When Sending request to URL : I Should get the Data " ERROR -
flex_user_code is missing." back insted i am getting "EEEER -
the code i am using is
DS_Open (URL, DSConst_ReadAutoUpdate, DSCallback, NULL, &dsHandle);
and in Callback function
DS_GetDataType (dsHandle, NULL, &size, NULL);
buffer = malloc (size + 1);
DS_GetDataValue (dsHandle, CAVT_CSTRING, buffer, size + 1, 0, 0);
did any one know wht the problem can be ?
(3,680 Views)
Hi Anonymous,
The code you posted looks correct (it appears to have been copied from the help section on DS_GetDataValue).
It is odd that the message contains the same number of characters in the beginning, but most have been replaced with 'E'. Is there a way you can verify with another program that this is indeed the message being sent? Also, is this a public URL that I could connect to and test it myself? If you can change the message, what string do you read if you replace it with "Hello World."
(3,648 Views)
The URL Is not public, it's QMS system on private server that i am
communicate with, when sending "Hello World" i am getting "HHHHo
World".
Doing the Same with labView ( Using dataSocket ) bring the same
results ( same Problem ), so i don't think that the code is the
Problem, may be same DLL. both application using.
But when using Microsoft IE6 i am getting back the string i am looking
for ( e.g Hello World ).
Shimon Kringel
Actelis Networks.
On Jan 27, 12:10 am, James M <x...@no.email> wrote:
> Hi Anonymous,The code you posted looks correct (it appears to have been copied from the help section on
> DS_GetDataValue).It is odd that the message contains the same number of characters in the beginning, but most have been replaced with 'E'. Is there a way you can verify with another program that this is indeed the message being sent? Also, is this a public URL that I could connect to and test it myself? If you can change the message, what string do you read if you replace it with "Hello World."Regards,
(3,642 Views)
Hi Shimon,
I wrote a simple datasocket program in LabVIEW and connected to http://ni.com. The first line in the string I read was:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
I verified that this is correct using "View Source" in Internet Explorer. If you point your program to
http://ni.com, what do you see?
If you are reading the correct value, I'm afraid there may be something wrong with the QMS system. What versions of CVI/LabVIEW are you using?
(3,605 Views)
