LabWindows/CVI
34401a rs232 driver
hello all
i'm searching the driver for 34401 agilent instrement used rs232 to integrate in lab windows cvi
please ho can help me to find't
thanks all
Message 1 of 8
(4,948 Views)
Message 2 of 8
(4,946 Views)
my brother before asking help i search in all the support this the file found't in your link this driver is for gpib not for rs232
Message 3 of 8
(4,944 Views)
I have not used this driver myself, but the NI site says serial...
Interface(s):
LXI, Ethernet, USB, IEEE 488.2 (GPIB), Serial
Message 4 of 8
(4,935 Views)
yes i know 🙂 but is try to seacrch in this driver but is not for rs232 take a lock i this help file html
Message 5 of 8
(4,933 Views)
What is the name that the system gave to your device? This data type uses a VISA resource data type (ViRsrc) that handles both serial and GPIB communication. Try to initialize the device with hp34401a_init and the correct name and see if the function throws any errors.
Best Regards,
-KP
Kurt P
Automated Test Software R&D
Message 6 of 8
(4,892 Views)
Deep thread revival.
I've downloaded this driver and tried following these instructions, but although the installer has output a load of .cab and .msi files, there are no .fp or compilable source files. What next?
Message 7 of 8
(4,532 Views)
I haven't installed the driver and I won't do it, but if the file outputs .cab and .msi files I suppose it will have generated also an installer that will extract from the the relevant files. Isn't there any setup.exe or similar program?
Message 8 of 8
(4,526 Views)
