LabWindows/CVI User Group Discussions
"Edit Label/Value Pairs"
Does anyone know how to get a list of lables and values from a ring control?
I use a ring control to select indivdual tests for diagnostic and would like to get a printout  rather than hand generating a list for documentation.
It would be nice if there was a print button on the panel that prints the list out.
Thanks.
(5,087 Views)
Paul
I am using the following functions:
   GetCtrlVal(nPanelHandle, PANEL_RING_SEQUENCE, &nTestMode);
   GetLabelFromIndex(nPanelHandle,PANEL_RING_SEQUENCE,nTestMode,sTestMode);
Based on the "nTestMode" value, I can get the Label associated with the value the user selected.
Regards
John
(3,695 Views)
John,
I use these functions inside my code.  I was more looking for a way to get the information so that I can document my test in a Word  doc.
I probably should just write a function that outputs the data to a text file.
Paul
(3,695 Views)
