LabWindows/CVI User Group Discussions
Sugested new feature for LabWindows
Yes, that makes sense.
Luis
Message 11 of 12
(1,740 Views)
Actually informations on the application can be obtained directly from the exe file, at least on Windows OS. Informations stored in Build >> Current settings >> Version info panel are stored in the compiled application and can be retrieved with some API calls: the following retrieves the "Product version" string stored in that panel.
    char    a[50], msg[128], file[MAX_PATHNAME_LEN], langName[16];
    UINT    len;
    DWORD   infoSize;
    DWORD   uselessParm;
    DWORD*  tempDWORD;
    GetProjectDir (file);
    MakePathname (file, pgm, file);   // Application pathname
    if (!(infoSize = GetFileVersionInfoSize (file, &uselessParm)))
        goto view;
    versionInfo = malloc (infoSize);
    if (versionInfo) {
        if (!GetFileVersionInfo (file, 0, infoSize, versionInfo))
            goto view;
        /* Get the Language and Code Page                                        */
        /*     The below 'hex' value looks a little confusing, but essentially   */
        /*     it is the hexidecimal representation of a couple different values */
        /*     that represent the language and character set that we are wanting */
        /*     string values for.  040904E4 is very common, it means:            */
        /*         US English, Windows MultiLingual characterset -- or:          */
        /*         04------    = SUBLANG_ENGLISH_USA                             */
        /*         --09----    = LANG_ENGLISH                                    */
        /*         --11----    = LANG_JAPANESE                                   */
        /*         ----04E4    = 1252 = Codepage for Windows:Multilingual        */
        if (VerQueryValue (versionInfo, TEXT("\\VarFileInfo\\Translation"),
                       ((void **)(&tempDWORD)), &len)) {
            /* lVerPointer is a pointer to four 4 bytes of Hex number, first two */
            /* bytes are language id, and last two bytes are code page. However, */
            /* Lang_Charset_String needs a string of 4 hex digits, the first two */
            /* characters correspond to the language id and last two the last two*/
            /* character correspond to the code page id.                         */
            langName[0] = 0;
            sprintf (langName, "%04hX%04hX", LOWORD (*tempDWORD),
                     HIWORD (*tempDWORD));
            if (langName[0]) {
                sprintf (msg, "\\StringFileInfo\\%s\\ProductVersion", langName);
                if (!VerQueryValue (versionInfo, TEXT (msg), &tempBuffer, &len) == 0)
                if (tempBuffer)
                    SetCtrlVal (panelHandle, PANEL_VERSION, (char*)tempBuffer);    // Show program version
For this to work you need to add version.lib to the project and #include <windows.h> (or at least winver.h: possibly some file more, I don't know)
Tip1: program filename is received by the Main () function in argv[0].
Tip2: do not forget to append a "+" to version fields you want to be incremented on each compilation
Message 12 of 12
(1,740 Views)
