LabWindows/CVI User Group Discussions
Released Compilation Revision
I Need to control every compilation releasement to manage the updates and use the Version information. How can I extract the Automatic Version number into a Report or a variable.
(9,894 Views)
Hello Arturo,
You can do something like that:
//Recupération des informations du fichier
char *GetInfo(char *InfoItem)
    static     char    szResult[256] = {0};
    char    szFullPath[256];
    char    szGetName[256];
    LPSTR   lpVersion;        // String pointer to Item text
    DWORD   dwVerInfoSize;    // Size of version information block
    DWORD   dwVerHnd=0;        // An 'ignored' parameter, always '0'
    UINT    uVersionLen;
    BOOL    bRetCode;
    GetModuleFileName (NULL, szFullPath, sizeof(szFullPath));
    dwVerInfoSize = GetFileVersionInfoSize(szFullPath, &dwVerHnd);
    if (dwVerInfoSize) {
        LPSTR   lpstrVffInfo;
        HANDLE  hMem;
        hMem = GlobalAlloc(GMEM_MOVEABLE, dwVerInfoSize);
        lpstrVffInfo  =  (LPSTR)GlobalLock(hMem);
        GetFileVersionInfo(szFullPath, dwVerHnd, dwVerInfoSize, lpstrVffInfo);
        // Get a codepage from base_file_info_sctructure
        lstrcpy(szGetName, "\\VarFileInfo\\Translation");
        uVersionLen   = 0;
        lpVersion     = NULL;
        bRetCode = VerQueryValue((LPVOID)lpstrVffInfo,
               (LPSTR)szGetName,
               (void **)&lpVersion,
               (UINT *)&uVersionLen);
        if ( bRetCode && uVersionLen && lpVersion) {
            sprintf(szResult, "%04x%04x", (WORD)(*((DWORD *)lpVersion)),
                (WORD)(*((DWORD *)lpVersion)>>16));
//            lstrcpy(szResult, lpVersion);
        else {
            // 041904b0 is a very common one, because it means:
            //   US English/Russia, Windows MultiLingual characterset
            // Or to pull it all apart:
            // 04------        = SUBLANG_ENGLISH_USA
            // --09----        = LANG_ENGLISH
            // --19----        = LANG_RUSSIA
            // ----04b0 = 1200 = Codepage for Windows:Multilingual
            lstrcpy(szResult, "041904b0");
        // Add a codepage to base_file_info_sctructure
        sprintf (szGetName, "\\StringFileInfo\\%s\\", szResult);
        // Get a specific item
        lstrcat (szGetName, InfoItem);
        uVersionLen   = 0;
        lpVersion     = NULL;
               (LPSTR)szGetName,
        else {
            lstrcpy(szResult, "");
    return szResult;
and then use it as here under:
//Recupération de la version de l'exe
sprintf(titre,"%s", GetInfo("ProductName"));
SetSystemAttribute (ATTR_TASKBAR_BUTTON_TEXT, GetInfo("ProductName"));
sprintf(titre,"%s %s", titre, GetInfo("ProductVersion"));
sprintf(titre,"%s %s", titre, GetInfo("Comments"));
SetPanelAttribute (g_iMainPanel, ATTR_TITLE, titre);
see ms link : http://msdn.microsoft.com/en-us/library/windows/desktop/ms647464(v=vs.85).aspx
(7,285 Views)
the problem is that you gave the path of the element that you want to get info from, but, I want to get the application itself to say hey this is my version. or compilation date. or something like that. to make it automatically then this value is set into a result file and the this result file is compared with a @golden@ or known result value and we can check if the application was compiled from another person or modified without changing the limit file or compared file.
(7,285 Views)
There are some predefine Macros that you can use.  Once you have them in a buffer you can write them to a file or compare them to you golden data.
sprintf(caMessage, "%d", _CVI_);
SetCtrlVal(ghAboutPanel, ABOUT_CVI_VERSION, caMessage);
sprintf(caMessage, "%s", COMPILE_DATE);
SetCtrlVal(ghAboutPanel, ABOUT_COMPILEDATE, caMessage);
sprintf(caMessage, "%s", _TARGET_FILE_VERSION_);
SetCtrlVal(ghAboutPanel, ABOUT_FILEVERSION, caMessage);
There is also the GetCVIVersion();  function.
Paul
(7,285 Views)
