All you need is a few days with LabWindows/CVI to become familiar with some of the more frequently used shortcut keys, but you may not have discovered some of the less frequently used shortcut keys that can really save you time when developing.
Below are some of the less frequently used LabWindows/CVI shortcut keys that you may not have discovered. These are located in the Miscellaneous section of the Change Shortcut Keys Window. This Window can be opened by selecting Options»Change Shortcut Keys in the LabWindows/CVI Development Environment.
Below are some of the more frequently used LabWindows/CVI shortcut keys:
File Menu
| Shortcut Action | Shortcut Key |
| New | Ctrl+N |
| Save | Ctrl+S |
| Open | Ctrl+O |
Edit Menu
| Find | Ctrl+F |
| Find in Files | Ctrl+Shift+F |
| Function Help | Shift F4 |
| Go to Next Reference | Ctrl+Shift+I |
| Replace | Ctrl+H |
| Replace in Files | Ctrl+Shift+H |
| Toggle Exclusion | Ctrl+E |
View Menu
| Beginning/End of Selection | Ctrl+J |
| Find Function Panel | Ctrl+Shift+P |
| Find UI Object | Ctrl+Shift+U |
| Expand/Collapse Region | Ctrl+Shift+F2 |
| Toggle Tag | Shift+F2 |
Arrange Menu
| Align | Ctrl+A |
| Distribute | Ctrl+D |
Code Menu
| Control Callback | Ctrl+B |
| Insert Function Call | Ctrl+I |
| Declare Variable | Ctrl+D |
| Panel Callback | Ctrl+P |
Build Menu
| Batch build | Ctrl+Shift+M |
| Compile File | Ctrl=K |
| Create Debuggable Executable | Ctrl+M |
Run Menu
| Add watch Expression | Ctrl+F7 |
| Breakpoints | Shift+F9 |
| Execute | Ctrl+F5 |
| Continue | F5 |
| Terminate Execution | Ctrl+F12 |
Tools Menu
| Go to Declaration | Ctrl=Shift+I |
| Go to Definition | Ctrl=I |
