LabWindows/CVI User Group Discussions
Inifile Read Bug
Hi, everyone.
If you write and read to the ini file, there is a problem when you use underscore for the item name.
If the same item name exists in the string prior to underscore, it causes problems.
In other words, one of the following two fails to read as a function of Ini_GetInt().
iABC_DE = 1
iABCDEF = 2
There was no problem in reading when replaced by other characters ('.', '/', '?) instead of underscore.
In other words, there is no problem when you do the following.
case 1. OK ------
iABC.DE = 1
iABCDEF = 2
case 2. OK ------
iABC/DE = 1
iABCDEF = 2
case 3. OK ------
iABC?DE = 1
iABCDEF = 2
I'm using Lab Windows/CVI 2020 version, and I'm sure there's no problem with other versions,
I wonder if you have a patch.
Upload the project files that you used for the test as well.
Thank you.
Message 1 of 1
(1,558 Views)
