y axis on waveform charts
I want to match the right and left axes on a waveform chart, even if the operator changes the scale on one side, the opposite side will update to match.  Is there an easy way to do this?
(2,796 Views)
Accepted by topic author ahhah
You can get an event and update the other scale with a property node.
Event = Graph.Scale Range Change
Property Node = Graph.Active Y scale (first scale) then .Range read this, set second scale activethen write duplicate range.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,786 Views)
Thanks!
(2,769 Views)
