xy value from chart
I would like to get the xy value from a chart whenever a user uses a mouse or click or keyboard or anything that would enable me to read an xy value from a chart.
I know this is easily done with cursors but I don't want to use a graph (long story).
My chart will also be manually scaled when data is finished so using the transparent graph on top of a chart is also NOT an option.
Any help would be greatly appreciated.
thanks !!
Message Edited by ugman on 05-28-2007 01:16 PM
(3,072 Views)
In general, you would simply use a "mouse down" event on the chart, which wil give you the coordinates in pixels. It is up to you to transform those into data coordinates. Easiest would be to use an invoke node linked to the chart with method "map coordinates to xy"
(I don't know what you mean by "keyboard or anything". How can you possibly pick a location with the keyboard?)
(3,063 Views)
Thanks for the quick response !!!
I will try this Smiley Happy
(3,058 Views)
Here's a quick example (LabVIEW 8.2.1)
Modify as needed. 🙂
Message Edited by altenbach on 05-28-2007 11:34 AM
(3,054 Views)
You are truly a Champion !!!
(3,046 Views)
