xy plot performance
Hi all,
I have a question regarding the performance of xy graph vs a chart. In my project i have been using a chart (Ichart history length to 24000pts) to plot 4 signals at a rate of 10Hz with no effect on the performance of my program. I recently switched to using an xy graph with the same conditions (I havent set an array size) and my  program slows down then locks up after about 1hr of running. I have attached a picture of the method which i am using to update the xy graph.
The VI has 3 main loops.
A UI loop with a event structure to handle user events running at 5Hz.
Data logging loop running at 10Hz (a subvi runs flat out every 100ms dumping data from a buffered network shared variable to file).
Display Loop updating charts and indicators (data is recieved via a network shared variable).
So, why does the chart perform so much better than the xy graph and can I get the xy graph to perform similarly?
(3,363 Views)
It is not clear from you graphics what you are doing. It seems a lit of crucial code is missing. Where is the databuffer?
Can you attach a real and functional VI instead?
From what I can tell you are using insert into array to build all the plot, constantly dancing between different data types (cluster, array, back to clusters, etc). Each resizing operation forces a new copy in memory. Not good!
What you need to do is allocate a fixed size array (initally all NaN) and operate on the data "in place" by replacing data. See how far you get.
(3,345 Views)
You have to remember, you are rebuilding the graph every time you update it. The chart is designed to update as you add points to the chart, not a complete rebuild.
(3,339 Views)
