xy-graph with two values without time
Hello
I try to plot two values in a xy graph. the first value should be represented in the y-axis and the other one in the x-axis.
The problem is, that i can't refer the x axis to this value becaus its always refered to "time".
Using Labview 7.1
(2,705 Views)
The x-axis on any graph is just labeled time as the default. Assuming that you have automatic tool selection on, all you have to is double click the label and change it to whatever you want.
(2,703 Views)
On Sun, 30 Jul 2006 12:40:07 -0500 (CDT), Simon790 <x@no.email> wrote:
>Hello
>I try to plot two&nbsp;values in a xy graph. the first value should be&nbsp;represented in the y-axis and the other one in the x-axis.
Right click on the x,y graph and click "visible items", then select
"scale legend". You can then change the title of the x axis.
TJW
(2,697 Views)
