In LabVIEW, version 6, Examples, General, Graphs, charts.llb, there is a VI named "Variable-Time Chart XY.vi". If one seeks contextual help on the xy-graph on the front panel or looks at the "description and tip" the VI author wrote specifically for this xy-graph on this VI, the following text appears.
"Displays the data. The delta X between points is determined by a tick count reading on the block diagram. Note that the XY Graph "scrolls" by setting the X axis range via the graph attribute node. A scrollbar could also be implemented to allow perusal of previous data."
My question revolves around the very last statement above, "A scrollbar could also be implemented to allow perusal of previous data."
Can someone share how
a scrollbar COULD BE IMPLEMENTED in that specific case?? Any help would be much appreciated.. thanks..
