xy graph of to different clusters
Thanks Codeman!
That's exactly what I was trying. Can you possible attach those two examples so I can download a clearer version of it.
Thanks again.
Message 11 of 13
(448 Views)
While loops with a False constant wired to the stop condition are not a good idea.  They are infinite loops and you'll be forced to hit the abort button to stop the VI.
Also having two DAQ assistants running in parallel will likely give you a "resource reserved" error if both DAQ assistants are pointing to the same DAQ device.
Message 12 of 13
(441 Views)
That is correct; though that last post was actually two separate diagrams pictured side by side and it was only inteded to illustrate different ways of combining data on an XY Graph.  Here are the two VIs back saved for LV 8.
Message 13 of 13
(435 Views)
