xy graph interpolation issue
 Hi all;
I'm looking for interpolation properties in XY graph. I really studied on. when I try to draw two or more curves on graph, it interpolates two curves. Actually, It connects by a line the end of first curve to tail of second curve. Please, tell me how to separate the curves. I attached output of graph and graph blocks. If it is required, I can choose curve fitting, can be useful. Please attach block diagrams that indicates your solution. I use Labview 7.
Thanks for your help
(4,069 Views)
Your miniature snippet of code doesn't really say anything other than the fact that you are creating an array of the same X and Y values. Why you are using local variables is a mystery. Please post your full code.
What exactly is there to interpolate on your curves?
(4,058 Views)
Seems you want to get rid of the "flyback trace".
Easiest would to insert an extra point containing NaN into your data whenever x jumps back. This wll suppress the line interpolation.
(Anyway, it almost looks lile your x values are equally spaced and the same for all plots. In this case you don't need an xy graph and a plain waveform graph will do just fine.)
Message Edited by altenbach on 09-16-2008 10:03 AM
(4,036 Views)
Thank you very much altenbach for your help, I applied your advice. It works. there is another question. I want to use curve fitting for each curve in order to get rid of instability.Do you have any tip about this when I working on it..  I'll attach screen shot, includes curve fitting applied.
Thanks again, You're great
(4,005 Views)
You have to be way more specific than that! 😄
On you image, I don't see any "curve fitting" just a cursor positioned at a somewhat random high point of the curve. In the text you say it includes curve fitting, but the filename is "without curve fit". So, what is it??? 😉
In order to curve fit, you need a mathematical model with a few fitting parameters (including estimates for them). Can you tell us a little bit more about the data? What kind of model do you have in mind? Do you have a formula? Are all curves independent or do you want to make a global fit, with e.g. one parameter varying according to some model as a function of each individual trace.
Can you attach your VI and some typical data?
(3,979 Views)
