xy graph , i have case with generated diferent arrays
Hello
I have case with A.B.C.D... options, each of this options creating different arrays wich can i want to display to the same xy graph. How can i create same graph in the diferent case ? When i creating second graph , this graph have different name a create me new graph, when i change name of graph then first , name was changed but it is not same graph.
thanks
(2,542 Views)
Hi
use a property node/ local variable of the xy Graph in each case and update its value
Regards
Dev
(2,536 Views)
