xml to Cluster/array
I dont have in 8.5.1 but i buy 2011 version then i can do the xml to array conversion using these vi??????? If so i can but 2011 version instead of 8.5.1
Thanks so much....
Message 11 of 15
(2,643 Views)
@Sim5 wrote:
HI,
Easy lab is not there in 8.5.1
It's called EasyXML, not Easy lab. It's not there in 8.5.1 because it's a separate toolkit distributed by JKI. http://jki.net/easyxml
Lab XML is another toolkit which i can't buy.
LabXML is free. Did you look at the link I provided?
Message 12 of 15
(2,639 Views)
Yes, you can use these functions in 2011. It gets kind of messy because you have to make sure you close each of the references you will be creating. If the XML file is very simple then you could just use the string functions.
Here is an example of what XML parsing looks like. This is from the example I was referring to.
LabVIEW 2012
Message 13 of 15
(2,637 Views)
I don't think the native xml parser functions were available in LabVIEW 8.5.  At least not in the installation I'm looking at.
Message 14 of 15
(2,631 Views)
Yes its not there 8.5.1
Message 15 of 15
(2,626 Views)
