xml parsing
I am new to labview is there any way to parse the xml?.please find the xml in the attachment.
varma
(2,929 Views)
Hi Varma,
  Please go thorugh this link..http://forums.ni.com/t5/LabVIEW/XML-file-data/m-p/1420958#M549752
SrikrishnaNF
Srikrishna
(2,925 Views)
You may also with to review the shipping examples. If you open the Example Finder (Help -> Find Examples) and search for "XML" you will find a "Load Test Configuration" which should get you started.
(2,905 Views)
if the xml is like an array of nodes i was fine with that ,but i have a problem in using the attributes?.
  <TestCase id="ALDL1" name="RESET">   ->how to use this tag?
          <Step cmdId="1" cmdName="DO SET" cmdType="0"> ->how to use this tag ?
please can you help  to parse this.
thanks
varma
(2,881 Views)
