xilinx 12.4 Download
Hi. I'm using the Labview 2011, I've installed the FPGA Module and the NI RIO but when I tried to compile my VI, it appears a message that says that the compilation tool are not installed, so I search on the web, I found that the one I need is the Xilinx 12.4, but when enter the web page, there isn't availabe downloads http://joule.ni.com/nidu/cds/view/p/id/2592/lang/en , what could i do? Is there anothe compilation tool I can use?
(5,433 Views)
It is kind of hidden, but there is a download link on that page.  It is a zip file towards the top of the pinkish area.
(5,430 Views)
No. It doesn't appear on my web page. Look...
(5,427 Views)
Ah.  That's because you haven't registered a LabVIEW FPGA to your account.  Do you have a license for LabVIEW FPGA?  Do you have the install discs still?  That would be the easiest way.
(5,424 Views)
Ohhh. Ok that's new for me cause i haven not done this to download other drivers, so let me try it. Thank you.
(5,418 Views)
And another way to do this, without the serial number?
(5,417 Views)
Hey there;
There is a KB; Wich Xilinx Compile Tools do I need to copile My FPGA Code? that includes the different links to the copile tools needed for every version of LabVIEW; the old driver and sofware versions can only be downloaded if you have SSP active.
You can activate SSP (which includes phone support and driver access) by updating your software or as an aditional product fromo your NI representative.
I found another link where you can get the tools directly fromo Xinix; however it will download all of Xininx's tools, later on the installer will allow you to chose which ones you want to install.
Hope this info helps
Greetings and good luck
(5,377 Views)
