x scale
Hi friends,
x scale of waveform graph is started negative value ve finished positive value. 0 point of graph isnot zero, for example it is "-3.39z". I would like that "-3.39z" point is zero. for this what can I do?
have nice work
(3,513 Views)
Hi number,
quick&dirty: change the formatting of the x scale values to %.3f…
You know what "3z" means? Ever heard of zepto?
(3,508 Views)
I don't know mean. formattin of scale is changed to %3f. but, when type of scale is SI notation, formatting is change automaticlly.
(3,500 Views)
Should you be using an X-Y graph?  A waveform is a samples af data (array) started at a time (t0) and with a known sample frequency (dt) in samples/sec
(3,495 Views)
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,483 Views)
