x-axis not plotting on a 3d image
Hi everybody.
Im trying to make a 3d image controlled by an accelerometer. I´m currently working with two potenciometers to simulate the accelerometer and I just cant get the x asis to have an effect on the image at all.
The y axis functions just fine.
I am using an arduino to acquire de analog signal from the two pots. I have already checked and I have both measurements donde correctly, it just doesn´t plot anything on y.
Im very new at Labview I hope someone can help me out.
Thanks a lot.
Eugenio A
(2,894 Views)
Eugenio,
Quote from the help for Set Rotation.vi:
"Clears any rotations previously applied to an object in a 3D scene and rotates the object by the values Axis and Angle. This VI performs an absolute rotation from the object's initial position."
Take a look at the Rotate Object.vi which does a relative rotation from the current position to see if it will do what you want.
Lynn
(2,892 Views)
I forgot to mention that you have very nice dial indicators.
Lynn
(2,890 Views)
Thanks for your answer!
I have already tried using the relative rotation VI and it did plot on both axis pretty well. The problem with the relative position is that whenever the accelerometer isn´t in a straight position (0 degrees on x and 0 degrees on y) it just keeps turning and turning, not showing the angles given by the accelerometer (because it adds the present value with the last value).
How can I solve this?
I´m sorry if it is hard to understand me but english isn´t my first language. 😉
pd. The dial indicators came with the arduino library hehe
(2,883 Views)
Got it solved by using the first vi with absolute position and the second one with relative position.
Thanks!
(2,879 Views)
