wtf4 rs232-USB
I am trying to setup a communication between the WTF4 controller and my Laptop (RS232 to USB).
I have installed the NI-Serial and the connection is OK. But there is an timeout error when reading back a string from the test panel.
Does anyone has any idea on this?
Thanks!
Message 1 of 30
(4,757 Views)
Have you looked at any of the hundreds of identical questions? What have you attempted? Does the instrument even support the *IDN? command?
Who makes this controller? Why haven't you attached the manual?
Message 2 of 30
(4,745 Views)
Yes, I did checked the similar questions but nothing helps.
WATLOW makes this controller. It is WTF4. What manual do you refer to?
Thanks!
Message 3 of 30
(4,740 Views)
The PROGRAMMING manual? Did you look in there before sending anything? You would obviously get a timeout if you sent the wrong command. Just as obviously, you would get a timeout if you were using the wrong type of cable or the wrong com settings. You have not mentioned what you have tried.
Message 4 of 30
(4,738 Views)
I am not sure if it supports *IDN but I have tried every all command.
Also I did "Enable Termination Charateristics".
Thanks!
Message 5 of 30
(4,737 Views)
The cable is a RS232 to USB cable from NI that should be the correct one.
WATLOW does not have the PROGRAMMING manual that I need. In the user's manuel, they only tell about how to "program" on the control panel.
So I have no clue next...
Message 6 of 30
(4,735 Views)
If you don't have a manual the communication interface, then you have no chance unless there is an existing driver. You really have no idea if the NI cable is correct. There needs to be a cable between the adapter and the watlow and there are two wiring schemes for cables. Without a manual, do you even know if the baud rate is correct?
Post back when you've gotten the manual and had a chance to study it.
Message 7 of 30
(4,730 Views)
NI Provides a driver.The initialize VI is not working due to the same problem.
So I come back to the MAX.
Thank you anyway!
Message 8 of 30
(4,721 Views)
As seen in other threads, if you are on Windows, you could use Sysinternals PortMon to see the commands sent by Watlow's app.
Message 9 of 30
(4,707 Views)
Message 10 of 30
(4,675 Views)
