writing to specific excel cells
Is it possible to write to an EXISTING file to one specified cell? I have tried using write to xl.vi as an example, but this rewites the entire file and I lose my old data.
I would greately appreciate any advice!
Thank-you,
Ivanka
(3,119 Views)
Ibahka,
Take a look at the modified example. I show how to open an existing File and sheet. From your post I am not sure if you got that far or not.
Anyways you can then use Set Cell Value.vi SubVI to set the value of an 1 cell in the file and worksheet you just opened.
The example does that in a loop, thus re-writes all the data. However if you only want to set 1 cell, take the VI out of the loop, and use it independantly.
See how I changed the 0,0 cell after all the data is set.
(3,119 Views)
Don't forget to use the Example Finder (Help >> Find Examples...) when you need help figuring out how to do something. Evan modified the example that ships with LabVIEW (by the same name) to help you out. There are a couple of other Excel examples you might be interested in.
Good luck,
Roy
(3,119 Views)
Thanks Roy,
I had looked at some of those examples (Write table to XL.vi) and was still confused.
Ivanka
(3,119 Views)
