writing to excel file from DAQ assistant
I'm currently using the National Instruments USB-6211 Data Acquisition card to acquire 3 signals simultaneously, one of which is temperature.  I am reading 1000 samples each second and it is working fine, but I'm looking to output the temperature to an excel spreadsheet once every minute with just one value being entered each time and not 1000.  Is there a way to achieve this?
Thanks!
(4,604 Views)
Sure. The simplest way is to use one of the built-in functions (Write Measurement File/Write to Spreadsheet File) which will create a text file that Excel can easily import. For the timing, you could use the Elapsed Time function and wire the Time Has Elapsed output to a case statement. Inside the case statement, either extract a single value or perform a mean of each channel and then write that.
(4,597 Views)
Thanks a million, worked perfectly
(4,577 Views)
