writing in consecutive columns of a table
Hi everyone,
I am relatively new to Labview and trying to write data collected from 20 instruments into a table. I would like to write first 20 readings on the first column of the table, second 20 on the second column and so on. I was thinking of increasing the table index somehow but couldn't figure this out.
Any help will be greatly appreciated. Thanks for your help in advance.
Melih
(2,834 Views)
Make a 2D array with 20 readings going into each row.  Then transpose the 2D array.  Like this:
Message Edited by tbob on 10-31-2005 01:22 PM
- tbob
Inventor of the WORM Global
(2,830 Views)
One solution is to use an insert into array node, wiring only the colum index, as in the attached picture.
Message Edité par chilly charly le 10-31-2005 09:23 PM
Chilly Charly    (aka CC)
(2,828 Views)
Thanks for the quick response. This writes end of the execution. What I would like to do is to read each entry and write it into the table. After completion of 20 readings, start from a new column.
Any suggestion?
Melih
(2,814 Views)
Use CC's method.  It writes to a column after 20 data points have been generated.
- tbob
(2,808 Views)
