writing cin
I am writing a CIN, and trying to compile it. My problem is understanding
these two lines:
\win32\lvsbutil $(TargetName) -d "$(WkspDir)\$(OutDir)"
$(OutDir)$(TargetName).lsb
I would just lke an explanation of what my paths for TargetName, WkspDir,
and OutDir should be. A simple explanation or example of what each would
be caled would suffice. Thanks
JMH
(2,944 Views)
JMH wrote:
> Hi,
> these two lines:
= Location of the lvsbutil (typically c:\National
Instruments I think)
or where ever you installed LabVIEW
(TargetName) = name of the lsb you are creating (typically the same name as
the C code file.)
(WkspDir) = directory where temorary files are stored (typically c:\temp)
(OutDir) = directory where the completed lsb file should go
(labview loads this file so put it in the project you are working on / or some
where that LabVIEW can find it)
Same as above
argetName, WkspDir,
Kevin Kent
(2,944 Views)
