writing LAbVIEW data to spreadsheet
I have just started with labview.
i wish to write some data from the NI DAQ card into an excelfile continuously while the program executes.
Now, my data is variation of x coordinate with time.
i used the write to spreadsheet block as  shown in the attachment.
however, i am able to create only a .txt file and that too without the time index.
i wish to create excel file with the time and x coordinate data.
also samples are being taken within miliseconds and data must be recorded with that precision.
kindly help
(3,499 Views)
Hi Bgmnt,
Only as long as you use the blue DDT wire.
After conversion to a 2D array the timing information is lost! (So the problem is your fault. ;))
Yes, sure. "excelfiles" aka "CSV files" aka "spreadsheet files" are just formatted text files!
Then you need to save the timing information too!
Either use ExpressVIs all the time (there also is an ExpressVI to save data) - or use (the better approach of) no ExpressVIs and learn to program with LabVIEW… 😄
Saving with a certain "precision" is duty of the programmer!
As long as you cvreate the correct routines the program will do what you want it to do!
(3,478 Views)
I began working with LabVIEW 5 days ago.
Could you please help me out with the block diagram?
or if not, could you suggest me the way to learn labVIEW?
(3,470 Views)
Hi Bgmnz,
play with "Write Measurement File" ExpressVI (in the file functions palette)!
To learn LabVIEW:
- NI offers a lot of online FREE resources to learn LabVIEW, start here: www.learnni.com
- LabVIEW comes with a lot of example VIs, found in the ExampleFinder (help menu!)
- LabVIEW has a context help, always keep this window open to read a short description of the function you're working with and to find a link to the more extensive LabVIEW help…
(3,459 Views)
