write to text file
hi need help .
i have to write some data to text file.
let say i have a stationNumber=SED001, values a=1, b=2, c=3,
then stationNumber=SED002, values a=2, b=2, c=7,
i want all this write in a same txt file but in different line.
Message 1 of 9
(3,820 Views)
What you need to do is format the text appropriartely with the data and save the resulting string to file.
I'll illustrate with an example.
Be back soon,,
RayR
Message 2 of 9
(3,815 Views)
See attached example in LV8.5.
RayR
Message Edited by JoeLabView on 06-19-2008 10:01 PM
Message 3 of 9
(3,813 Views)
thk u but im using labview 8.0
Message 4 of 9
(3,808 Views)
All you need to create that VI from scratch is shown in the screenshot.Smiley Wink
Message 5 of 9
(3,806 Views)
thk u joe. actually it like this
the user will in insert the for example
SED=001, a=1,b=2,c=3,
and press ok to save it,
thn the user insert second data
SED=002, a=2, b=2, c=3,
i can save to text file for but the second data is overwriten the first data
how to make this second. third and so on... data inserted to different line.
Message 6 of 9
(3,802 Views)
Did you attach a True constant to the "Append Data" input to whichever Write File VI you are doing?
In Ray's example, all of the data is put together in one string (I assume he has a carriage return at the end of his format string) and written out in one shot at the end.  It will show up as different lines.  If yours is overwriting, then you must have structured your code differently.
Message 7 of 9
(3,795 Views)
do you hv any example which i can refer ?
Message 8 of 9
(3,790 Views)
Hi jeyanthi,
try this example.
Hope it helps
Mike
Message 9 of 9
(3,755 Views)
