write to spreadsheet
Hello!
I am having difficulty writing to spreadsheet. It tells me that the data is of different forms...? I have looked through numerous examples on this website and cannot figure out what I am connecting wrong. It seems that I have everything connected the same as a similar VI I have that is correctly wired and writes to a spreadsheet.
Thanks so much for your help!
(3,120 Views)
Your code is incomplete.
What exactly are you trying to write to spreadsheet?
I am guessing you want something like this?
(see attached snippet)
Message Edited by RTSLVU on 06-04-2010 12:46 PM
=== Engineer Ambiguously ===
(3,111 Views)
blizabeth37 wrote:
Hello!
You cannot create an array of different data types, like trying to combine a DBL with a Timestamp with a string.  You must convert all data to one type.  RTSLVU's example shows conversion to DBL before writing.  You can also convert everything to a string.  99% of the times, I use string because I also write column headers, which are strings.
- tbob
Inventor of the WORM Global
(3,094 Views)
Is there a point to this:
Message Edited by smercurio_fc on 06-04-2010 03:27 PM
(3,081 Views)
First off, that's not my code...
I tried to just highlight the part I changed to make the snippet.
LabVIEW added the constents when creating the snippet
Doh, that was in the origonal code, but it's still not mine...
Message Edited by RTSLVU on 06-04-2010 01:31 PM
(3,078 Views)
