write to spreadsheet append to file
I have two 2D data from measurement like those:
the first:
-1.000000E+0    5.102000E-10
-9.000000E-1    4.069000E-10
-8.000000E-1    3.149000E-10
-7.000000E-1    2.329000E-10
the second:
1.505356E-2    8.315681E+10
1.556519E-2    8.639427E+10
1.604228E-2    8.955526E+10
I used "write to spreadsheet" function to write to the file, for the second one, i set the "append to file" to "True". However, it will append the data at the bottom of the file. How can I append them side by side like:
-1.000000E+0    5.102000E-10   1.505356E-2    8.315681E+10
-9.000000E-1    4.069000E-10     1.556519E-2    8.639427E+10
-8.000000E-1    3.149000E-10      1.604228E-2    8.955526E+10
Thank,
Joyce
(2,864 Views)
Hi Joyce,
as a spreadsheet file is just a text file with some special formatting codes it will always append at the bottom...
But you can:
Load the first data, attach the new data in RAM (using any order you like), write a whole new spreadsheet file!
(2,862 Views)
Hi, GerdW,
How to attach the new data in RAM?
Joyce
(2,857 Views)
Accepted by topic author Joycezh
Instead of wirting to the file every time, put everything in an array and write it all at once and the end.
=== Engineer Ambiguously ===
(2,855 Views)
