write to spread sheet with out all the carrage returns
IM reading data from 12 sensors 10 pices of data each when i write to spread sheet i want the data for each sensor across no carrage return till next time stamp
here is my vi and how the data is being written
(3,127 Views)
Right click your build array and select "Concatinate inputs".  Remove the broken wire and rewire to the W2SS File 1D array input
"Should be" isn't "Is" -Jay
(3,119 Views)
i did try that but and data goes across but its in wrong order for example if i read out 3 items from 3 sensors
I get,
part num,part num, part num, s/n, s/n, s/n, data, data, data
i want
part num s/n data part num s/n data ect...........
(3,111 Views)
Accepted by topic author brian19876
Change the build array to an interleave arrays on the arrays and add the timestamp with a build array afterwards
(3,085 Views)
