write string to serial port ?
Hello! Thanks all, who help me build up this attached VI !!!
Small problem.
In a few words: I received date from serial port, my VI work with it, and I want pass string “sting I need write to port” to serial port. (see attached VI).
Data all time read from port and write to port.
I know, how work serial VISA, but I don’t know, how connect wire.
And second question: how insert subVI in VI from .llb?
Thanks!
Mikhail.
(4,378 Views)
to insert a subvi from a llb. Just do the same as for a "normal" subvi: Right click on diagram => Functions => Select a vi.
When you click on the llb it will be opened. Click on the vi you want to add: It is done.
In you diagram you used  the VISA write.vi in the write case. Use it again to write your string => copy/paste after Visa Read =>
disconnect top and bottom right wires from Visa Read => connect VISA Write to it.
Dai
Dai
LV 7.1 - WIN XP - RT - FP
(4,368 Views)
Hi  Dai!
Thanks for answer.
I did as you said, but something  I did wrong.
Please, look at my VI. What is wrong?
Mikhail.
(4,362 Views)
it looks alright. There is a missing vi (untitled one), I suppose you forgot to include it.
Not matter since I don't have the hardware I cannot test.
I suggest you debug it yourself using the Highlight Execution tool (the little light bulb next the run button).
Try to spot the problem: is the string you want to write correct? etc...
Dai
Dai
(4,360 Views)
Hi
It is all right.
Thanks fo help.
With greeting from Russia!
Mikhail.
(4,352 Views)
