write /read ini cluster limits / ogtk
Some one kows what is the limit with  "write  read ini cluster " from ogtk
i tried with array of cluster and it works well, but with with  composite cluster that report an error.
i create a composed cluster definie in vi attached , it reach to write and file seems to be well defined
but i don't succeed to read it after it send me error message.
best regards
important to read file "palier" palier.txt have to be rename in palier.cpt  else you can create one using write palier.vi
path is code in hard so you have to change path to your proper path in read palier.vi
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(4,486 Views)
i forgot error mess:
(4,481 Views)
Try replacing the timestamp with a double.
This might help, or use a string that stores the timestamp.
Ton
My LabVIEW Ideas
(4,452 Views)
thanks, that seems to solve the probleme, i make some tries
with string and double conversion and i will close the post,
or in few words can you tell me advantages/inconveniens between both ?
regards
Tinnitus
(4,439 Views)
Accepted by topic author tinnitus
It depends on the level of accuracy you need. I think the string is your best option.
Ton
My LabVIEW Ideas
(4,422 Views)
hello TCPlomp,
You think using double , I can lose resolution,   for this application 1s rsolution is needed
but it will be interresting to know how double conversion limit  timestamp resolution
best regards
Tinnitus
(4,417 Views)
