write /read 32bit serial number
hi,
i want to read and display the 32 bit serail number and then want to store in a text file. when ever i scan the new serial number, every time it has to store new number .
(2,785 Views)
Accepted by topic author sandy1
What exactly is the problem you are having? The task is very simple and has been discussed before. If you are using a bar code scanner, just search the forum for that. If you would post the code you've written, someone could look at it and see what the problem is (if in fact you describe the problem).
And in case you haven't seen it before, there are tutorials available.
(2,780 Views)
