write logaritm scale to dsc
I would like to log values between 1000 and 1e-9 (it is a value for vacuum pressure). 1000 mbar is atm. pressure and we can measure down to 1e-9 mbar.
When I log to DSC I can use the value deathband 0.01%. This means the smallest value is 0.01 mbar. This is the same as 1e-2 so I do miss 7 decades of values. The value resolution is also not going down to 1e-9. When I make from both values 0, the logging is working, but I get a lot of data. I would like to log less frequent. Or at certain time intervals (for example every second).
Is there a way to reduce the data collection I have right now?
Rens
Message 1 of 1
(2,473 Views)
