write into table
Hi all,
I am trying to write measurement from instrucment using I/O assistant into table. but the result are written to the first line continuously, which was not what I need. What i wanna is also following. An a pic of my program
Level Current              Level Avg                     Level Min                        Level Max
123                              123                              123                                 123
456                              456                              456                                 456
(3,421 Views)
HI
can you upload the snapshot of your program or vi, so we can see and figure out your problem
Regards
Santosh
(3,420 Views)
Please check this link. Should help you solve your problem.
http://forums.ni.com/ni/board/message?board.id=140&message.id=34011&requireLogin=False
(3,372 Views)
Hi Lawn,
You might want to try this example as well.it will allow to store the data in differnt column.
Don't forget to vote from Kudo!
S.AHMAD.
AE
(3,349 Views)
Hi all,
I have manage to solve the problem. Thank.
(3,329 Views)
