write in a formfield in word, with toolkit report generation
Hello  all !
I am trying to write values in a word table containing formfields. My Vi is working fine ecept of one fact :
- The formfields are erased when a value is written.
Is there any method in the toolkit "report generation" that allows to write in formfields ?
I made an example VI to show you my problem
Thanks in advance for your answers
Thibaud
(4,020 Views)
Accepted by topic author ThibaudP
ThibaudP a écrit :
Hello  all !
Thibaud
First, what you have are not formfields but ContentControl objects. When you use Word Edit Cell.vi you are replacing the actual content of the cell (the ContentControl object) by plain text. What you need to do is to edit the text property value of the range of the ContentControl object that is contained in the cell.
There is no Report Generation Toolkit vi that can do it. What you can do is to get the table activeX reference from the Word Get ActiveX References.vi and do as in the following code snippet.
Ben64
(3,980 Views)
How do I find that object in the pellet, right behind the ActiveX Word object?
(1,648 Views)
Those are Invoke nodes (with the arrow) and property nodes (with the wrench). You can find these nodes in the Application Control palette.
(1,633 Views)
Thanks found it. I am new to labview. What exactly is the difference between property and invoke node? To me they look like very similar functions, and I am not too sure what distinguishes them.
(1,624 Views)
