write files
I have a graph that receive data in a continuous way,¿ how can i save the information received,activating a boolean that opens the "save window"of Windows system?
(2,740 Views)
Look at some of the examples that ship with LabView like Write Datalog File Example.vi. To find the example, from any LabView window goto Help >> Find Examples >> Search and enter "datalog" in the box labeled Type a keyword to find:
If you don't want to use datalog files, you can open a file with the Open/Create/Replace File function from the File I/O palette. If you don't wire the file path input, a dialog pops up to select or enter a file name.
(2,740 Views)
